[Vkontakte Login] - Регистрация и вход пользователей из ВКонтакте
Автор a_l, 26 марта 2011, 20:40:59
AstaLaVista
Цитата: GeorG от 05 октября 2011, 08:29:14
А какая есть?
function template_body_above()
   global $context, $settings, $options, $scripturl, $txt, $modSettings;
echo !empty($settings['forum_width']) ? '
<div id="wrapper" style="width: ' . $settings['forum_width'] . '">' : '', '
    <div id="header">
        <div id="head-l">
             <div id="head-r">
                 <div id="userarea" class="smalltext">';
                  if ($context['user']['is_logged'])
                  if (!empty($context['user']['avatar']))
                     <div id="my-avatar" class="clearfix">', $context['user']['avatar']['image'], '</div>';
                   <ul class="reset">
                      <li><b>', $txt['hello_member'], ' ', $context['user']['name'], '</b></li>';
                      <li><a href="', $scripturl, '?action=unread">', $txt['unread_since_visit'], '</a></li>
                      <li><a href="', $scripturl, '?action=unreadreplies">', $txt['show_unread_replies'], '</a></li>
                       <li>', $context['current_time'],'</li>
                   </ul>';
         // Otherwise they're a guest - this time ask them to either register or login - lazy bums...
         echo sprintf($txt['welcome_guest'], $txt['guest_title']);
              <script type="text/javascript" src="', $settings['default_theme_url'], '/scripts/sha1.js"></script>
              <form action="', $scripturl, '?action=login2" method="post" accept-charset="', $context['character_set'], '" style="margin: 4px 0;"', empty($context['disable_login_hashing']) ? ' onsubmit="hashLoginPassword(this, \'' . $context['session_id'] . '\');"' : '', '>
               <input type="text" name="user" class="userlog"  size="10" />
               <input type="password" name="passwrd" class="userlog"  size="10" />
               <input type="submit" value="', $txt['login'], '" class="button_submit" />
               <input type="hidden" name="hash_passwrd" value="" />
            </form>', $context['current_time'],'<br />';
     </div>';
                    // Show a random news item? (or you could pick one from news_lines...)
                    if (!empty($settings['enable_news']))
                      echo '<div id="news">
                     <br /><b>', $txt['news'], ':</b> ', $context['random_news_line'], '</div>';
             <div id="logo">
            <a href="', $scripturl, '">', empty($context['header_logo_url_html_safe']) ? '<img src="'. $settings['images_url']. '/theme/logo.png" alt="' . $context['forum_name'] . '" title="' . $context['forum_name'] . '" />' : '<img src="' . $context['header_logo_url_html_safe'] . '" alt="' . $context['forum_name'] . '" title="' . $context['forum_name'] . '" />', '</a>
          </div>';
        <div id="toolbar">
        ',template_menu(),'
         <div id="bodyarea">';
          theme_linktree();
Установл. моды: TinyPortal 1.0; RedirectPage; Sitemap
AstaLaVista
Вы про это?
Строка 329
// Show the menu up top. Something like [home] [help] [profile] [logout]...
function template_menu()
   global $context, $settings, $options, $scripturl, $txt;
      <div id="topnav">
         <ul>';
   foreach ($context['menu_buttons'] as $act => $button)
            <li id="button_', $act, '">
               <a class="', $button['active_button'] ? 'active ' : '', '" href="', $button['href'], '"', isset($button['target']) ? ' target="' . $button['target'] . '"' : '', '>', $button['title'], '</a>';
      if (!empty($button['sub_buttons']))
               <ul>';
         foreach ($button['sub_buttons'] as $childbutton)
                  <li>
                     <a href="', $childbutton['href'], '"', isset($childbutton['target']) ? ' target="' . $childbutton['target'] . '"' : '', '>', $childbutton['title'], !empty($childbutton['sub_buttons']) ? '...' : '', '</a>';
            // 3rd level menus :)
            if (!empty($childbutton['sub_buttons']))
                     <ul>';
               foreach ($childbutton['sub_buttons'] as $grandchildbutton)
                        <li>
                           <a href="', $grandchildbutton['href'], '"', isset($grandchildbutton['target']) ? ' target="' . $grandchildbutton['target'] . '"' : '', '>', $grandchildbutton['title'], '</a>
                        </li>';
                  </ul>';
                  </li>';
               </ul>';
            </li>';
         </ul>
      </div>';
saks
#154
Поставил мод 1.3 на SMF 2.0 . Все вроде хорошо. но при попытке склейки аккаунта выдает Hacking attempt... с чем это может быть связано ?
Попробовал тоже самое на демо сайте - результат тот же , скрейка не получается, выдает Hacking attempt...
a_l
ЦитироватьВсе вроде хорошо. но при попытке склейки аккаунта выдает Hacking attempt... с чем это может быть связано ?
При входе через вконтакте создаётся аккаунт SMF, к нему привязывается соответствующий ID вконтакте. Нельзя привязать ID к нескольким аккаунтам.
saks
то есть если я один раз вошел под учеткой в контакте то уже привязать акаунт не получится , дляэтого ее надо удалить вначале ?
a_l
Правильно поняли.
AstaLaVista
Цитата: AstaLaVista от 05 октября 2011, 06:48:40
Мод установился на 2.0.1, но помогите пожалуста, установить кнопку входа в тему ProRed
http://custom.simplemachines.org/themes/index.php?lemma=2380
Ошибка:
3.   Добавить после    ./Themes/ProRed2/index.template.php   Неудачно
Код: (Найти )
elseif (!empty($context['show_login_bar']))
Код: (Добавить после )
   if (!empty($modSettings['VKAppId']))
   echo '<div id="vk_auth"></div>
   <script type="text/javascript">
   window.onload = function ()
   VK.init({apiId: ' . $modSettings['VKAppId'] . '});
   VK.Widgets.Auth("vk_auth", {width: "200px", authUrl: \'index.php?vklogin\'});
   </script>';
Нету там такой строки!!!! - elseif (!empty($context['show_login_bar']))
Ну, что так никто и не поможет?
Скажите тогда, хоть сколько стоить будет?
Прикрепите во вложения ваш файл index.template.php с темы ProRed (предварительно его поместите его в архив).
AstaLaVista
Прикрепил...
AstaLaVista
Это не баг, просто шапка у вас, фиксированная по высоте, и естественно текст формы, стал ниже, потому что выше, добавилась форма Вконтакта. Сделайте обтекания текста или увеличите высоту шапки.
AstaLaVista
Все, кажись сделал!!! Огромное спасибо GeorG за помощь!
Nimmul
Tair
Поставил мод, ошибки поправил вручную. Но не работает. Я так понимаю, что приложения проходят сначала модерацию?
a_l
Веб-сайты раньше не проходили, может что сейчас изменилось.
Tair
Кстати, а мод PrettyURLs как-то может повлиять на работоспособность мода?
molatok
Объясните где вставлять это -
Цитироватьif (!empty($modSettings['VKAppId']))
   </script>';
если в файле нет
Цитироватьelseif (!empty($context['show_login_bar']))
Вкладываю сам файл в аттаче.
Не мог удержаться - bann
Например перед (или сразу за) строчкой:
В общем в том условии, которое выводится гостю.
molatok
насколько я понимаю (в php не очень-то)
вот это
Цитироватьecho '
                        <script language="JavaScript" type="text/javascript" src="', $settings['default_theme_url'], '/scripts/sha1.js"></script>
                              <input type="text" name="user"  size="10" />
                              <input type="password" name="passwrd"  size="10" />
                              <select name="cookielength">
                                 <option value="60">', $txt['one_hour'], '</option>
                                 <option value="1440">', $txt['one_day'], '</option>
                                 <option value="10080">', $txt['one_week'], '</option>
                                 <option value="43200">', $txt['one_month'], '</option>
                                 <option value="-1" selected="selected">', $txt['forever'], '</option>
                              </select>
                              <input type="submit" value="', $txt['login'], '" />
                           </form>', $txt['quick_login_dec'], '<br /><br />';
есть форма входа.
если код ставить перед ней (до и после строчки echo sprintf($txt['welcome_guest'], $txt['guest_title']);) ничего не меняется. Впрочем, как и после этой формы.
А вот если вместо нее, то все равно ничего не появляется, только форма уже исчезает...%)
a_l
molatok, в админке указали id и ключ? Если они не указаны, форма входа через вконтакте отображаться не будет.
Tair, не знаю - не проверял.
molatok
Цитата: molatok от 28 ноября 2011, 13:31:45Да. Работает только под одной темой %)
Ну вы в другой так же пропишите, и там заработает тоже.
molatok
Tair
Цитата: a_l от 28 ноября 2011, 13:26:14Tair, не знаю - не проверял.
работает.
Кстати, а можно сам виджет немного поменять визуально?
И ещё - возможно ли будет добавить запрос пользователю при авторизации на добавление реального email?
a_l
ЦитироватьКстати, а можно сам виджет немного поменять визуально?
Нет, виджеты от вконтакте поменять визуально не получится.
ЦитироватьИ ещё - возможно ли будет добавить запрос пользователю при авторизации на добавление реального email?
Всё возможно ;) Для этого придётся делать промежуточную страницу, на которой просить почту.
А ещё можно мод переписать на Vkontakte API, это правильнее и методов там много (правда не уверен, что почту можно получить), но я этого делать не собираюсь.
John Gray
На 2.0.1 не ставится. Сделал эмуляцию до 2.0. Пишет:
3.    Изменение файла    ./Themes/default/index.template.php    Неудачно
      1.    Добавить перед    ./Themes/default/index.template.php    Успешно
      2.    Добавить после    ./Themes/default/index.template.php    Успешно
      3.    Добавить после    ./Themes/default/index.template.php    Неудачно
Код: (Найти ) [Выделить]
Код: (Добавить после ) [Выделить]
   </script>';
Вряд ли вам что-то внятное смогут ответить, тут индивидуально, скорее всего мешают уже установленные моды... Можете обратится ко мне (читайте подпись) или почитать этот форум, может и сами сделаете.
newlipetsk
Ни кто еще не решил проблему, что бы email подтягивался с учетки Вконтакте, а не генерировался вида idпользователя@vkontakte.ru? А то с уведомлениями для пользователей беда, не приходят к ним письма! А сами они менять email не умеют, так как контингент форума моего это девушки и женщины! Если кто решил проблему напишите пожалуйста, может какие то другие пути решения есть! Очень нужна ваша помощь!
Dexus
А как сделать, чтобы на автаре менялось изображение, когда юзер меняет его у себя в профиле в вконтакте, а то жалуются, что не могут опознать свои посты при беглом просмотре страницы форума.
Я понимаю, что мелочь, но как то хотелось бы приятно  :D
Ну дык... Если пользователь написал уже несколько постов, то я думаю он может себе позволить, зайти к себе в профиль на форуме, и поставить туда свой аватар (в нашем случае с Вконтакта). А если не написал ещё, то и путаться ему не в чем.
Dexus
a_l
Dexus, интересное предложение, и это даже можно сделать. Но есть другая сторона - что, если люди не хотят, чтобы их ава вконтакте была авой на форуме? Да и фото из вконтакте в качестве авы (пусть даже на форуме установлен размер 200*200) не шибко смотрится, многие любят gif-ки ставить.
А не хочет ли уважаемый автор сделать к этому моду аддон? Что бы создаваемые на форуме темы - автоматом постились на стене указанной группы)
Или может такое уже где то есть а я не знаю?
a_l
kak2z, с модом подобный аддон мало что связывает. Условно говоря, в моде получаем информацию от вк, а в предлагаемом аддоне нужно отправлять. Соответственно, методы работы другие - wall.post через их API.
Мод постинга на стену был в планах, и вместе с ним ещё несколько для своего форума. Но эти планы пока отложены в далёкий ящик.
Я на хабре нашел описание.. http://habrahabr.ru/blogs/social_networks/113968/
попробую сам его приспособить к СМФ.. но моды я не умею делать еще)
a_l
kak2z, не нужно делать как там написано. Для этого существует API, и нужно обращаться через него:
http://vk.com/developers.php?oid=-1&p=wall.post
Да я вроде видел.. но там вроде публикуется на стену пользователю. А мне надо в группу. Я конечно далек от ВКонтакта и могу ошибаться)
z00m
прошу помощи с модом.
установил мод, на стандартной теме все работает, но когда включаю свою окно авторизации ВК не появляеться, что уже не пытался сделать, не могу понят :facepalm:
прошу помочь
в аттаче файл Index.template
Sysreg
Подскажите пожалуйста, у меня нет возможности использовать собственный сервер, php и т.д. Я сделал Iframe приложение Вконтакте, где выводится моя страничка со стороннего хостинга, где ввиде html я разместил тот самый скрипт от VK:
<!-- Put this script tag to the <head> of your page -->
<script type="text/javascript" src="http://userapi.com/js/api/openapi.js?49"></script>
  VK.init({apiId: №№№№№№№});
<!-- Put this div tag to the place, where Auth block will be -->
VK.Widgets.Auth("vk_auth", {width: "300px", onAuth: function(data) {
alert('user '+data['uid']+' authorized');
Как можно сделать чтобы кнопка 'нажималась автоматически" и желательно была скрыта от глаз посетителя
(при этом результаты заходов в виде иконок можно оставить как прежде)
Тоесть чтобы при посещении приложения все гости автоматически добавлялись в список.
Возможно ли это? Спасибо...
a_l
ЦитироватьВозможно ли это? Спасибо...
Этого, разумеется, нельзя сделать.
Homosap1ens
Скажите пожалуйста, а в чем может быть проблема? У меня не удаляется мод. Пишет:
Этот пакет не может быть удален, потому что в нем нет программы удаления!
Пожалуйста, обратитесь к автору пакета, для более полной информации.
В чем может быть проблема?
Kroose
spinus
Цитата: AstaLaVista от 20 октября 2011, 20:26:58
Вот такой баг получился... :'(
У меня точно также, шапка съехала, помогите пожалуйста, как поправить, сss не знаю. Тема overviewlight 2.0
Simple portal 2.3.6
как минимум index.template.php index.css
приложите в архиве
spinus
Simple portal 2.3.6
